- Mich_FExplorerI doubt the W/D hitch is advisable for a C or any vehicle with a frame extension. That extension is the weak point, and the main reason, I believe, for C manufacturers downgrading, in some cases by a lot, the GCWR of the vehicle. Perhaps it would work as intended, but it naturally depends on how well the MH manufacturer has added on that extension. It would be nice if they could get the vehicle manufacturers to put out these vehicles with longer frames and eliminate the need for extensions.
I have a 97 24' Coachmen that had a 3,500# hitch when I bought it. I pulled that off and had a local metal fabrication shop build a custom hitch that ties into the main frame. As far as I'm concerned, that vehicle can tow up to it's GCWR. - j-dExplorer IIIs a Weight Distrubuting Hitch OK with the C's Frame Extensions? It reduces Tongue Weight on the Hitch Ball and Rear Axle but it jacks that weight to the Front Axle via Frame and Extensions.
I can picture where a C/TT combo might drive pretty well. Most of us have plenty of front axle capacity for the WD hitch, may actually be running Front Light, and the TT's Sway Control could help with, well, Sway. - DakzukiExplorer
Wikid86 wrote:
Road Princess wrote:
I have to assume that the travel trailer's umbilical will be plugged into the receiver on the back of the class C. You will need those trailer brakes to fire off when stopping such a combination.
True. I recommend brakes over 2500 lbs. Texas law requires 4500 lbs plus. My particular TT I towed behind the Class C is 4400, but I still use brakes, weight distribution, and sway control.
Better safe than sorry!!!
http://law.onecle.com/texas/transportation/547.401.00.html
In my state it's 3000 lbs. I tow a smallish utility trailer behind the RV without brakes but I have supplemental braking for the toad when I tow it. It is just under 3000 lbs but I'd rather be safe. - Wikid86Explorer
http://law.onecle.com/texas/transportation/547.401.00.html - Road_PrincessExplorerI have to assume that the travel trailer's umbilical will be plugged into the receiver on the back of the class C. You will need those trailer brakes to fire off when stopping such a combination.
- DakzukiExplorer
RetSgt7114 wrote:
kennyd63 wrote:
Hello there-
My wife seen a class C towing a TT. Is this is legal as long as you have a CDL? or is not allowed?
Thank you, in advance
Kennedy>>>
As stated, as long as you do not exceed the length restrictions (usually 65 feet) or go over the GCWR, you should be good to go.
...and remember the tongue weight counts as weight in the RV. - crassterExplorer IISure, but I'm not towing much with my 4 cylinder Toyota class C. LOL
It is legal ^^ as above posts have stated. - RetSgt7114Explorer
kennyd63 wrote:
Hello there-
Kennedy>>>
As stated, as long as you do not exceed the length restrictions (usually 65 feet) or go over the GCWR, you should be good to go. - ksg5000ExplorerJust make sure your Class C has the weight capacity - I have a 29' E350 which is pretty much maxed out coming off the dealer lot.
- RobertRyanExplorerIn Europe you have quite a few Vans and Class C's pulling Caravans
Here it is small or medium sized SUV's. Class C Motorhome towing a small CUV.
About Motorhome Group
38,708 PostsLatest Activity: Mar 06, 2025
