Fishinghat wrote:
I was warned by several friends not to use the box type that fits in front of the driver's seat and depends on changes in inertia to detect a braking action and press down on the brake pedal. Apparently, they frequently fail and apply the brakes when not required. Still, a lot of RV owners use these systems. They connect to the power outlet in the dash and can be moved to any towed vehicle, so they don't require any modifications to either vehicle.
I would not take any more advice/warnings from these "several friends". I used a brake buddy for many years with no issues. I adjusted it so that it would only come on under relatively severe braking, didn't want the toad to stop the motorhome, and plugged it into a separate jump/emergency start battery jobby so it wouldn't run down the toad battery or need another wire from the MH.
I used it in several different toads.
and for those who don't use a braking system, check your owner's manual and see if it isn't recommended for toads weighing over xXX lbs. just because you didn't read it doesn't mean that the lawyer for the people you hit won't.
bumpy
