โMay-25-2013 08:02 PM
โMay-28-2013 02:22 PM
Dutch_12078 wrote:edatlanta wrote:
I have the TST 507 system and to do what the OP originally asked you could program the unit in reverse. Program what would be the toad sensors as the front vehicle and the MH sensors as the trailer. Then when driving only the toad you can turn off the "trailer" which would leave you with the toad sensors actually showing/scanning.
It wouldn't be a problem as long as you knew what the system was telling you.
That does give you a pretty funky looking display though. Does the 507 support an 8 wheel "trailer"?
โMay-26-2013 05:54 PM
โMay-26-2013 05:15 PM
โMay-26-2013 01:23 PM
โMay-26-2013 10:31 AM
โMay-26-2013 08:50 AM
โMay-26-2013 05:22 AM
โMay-26-2013 04:57 AM
โMay-25-2013 11:03 PM
โMay-25-2013 09:33 PM
โMay-25-2013 08:40 PM
โMay-25-2013 08:35 PM
fcooper wrote:
I've been looking at the newer TPMS systems The TST 507 system, the Tire Tracker/Tire Minder/Hawkshead (same manufacturer) and the 508 system from eez rv products all seem to do the same basic pressure/temp reporting. Most owners report that these units work well.
I would like to be able to have a monitor that will work for the motorhome and toad while towing, and then be able to move the monitor into the toad when driving the toad without having to do a lot of reprogramming.
Do any of the units mentioned above allow this use of the monitor in the toad without reprogramming?
Thanks
Fred
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โMay-25-2013 08:18 PM
