rooster
Jun 03, 2014Explorer
Tradewinds door problem
Hope somebody with an older Tradewinds has solved this problem. Mine is a '99, & the front door ddoes not seal properly around the top. Very noisy, VERY ! I've tried new weatherstripping, several times, & adjusting the latches. Nothing seems to work for very long. If you look at the outside of the closed door, you can see the top is away drom the coach by maybe 1/2 inch. Help!
