Teleman's avatar
Teleman
Turn signals, brake lights blow fuses ONLY when motor is on
They work fine with ignition switched on but motor off. 88 Coachmen,P30,454.Voltage regulator? If so where is it located? If not any ideas?
  • Voltage regulator is internal to the alternator.
    Check voltage output from the alternator.
