Jim Norman wrote:
I have a Plug-In Surge Protector.
My new Coach has a built in Surge Protector.
So Can I use both?
Does it make a better protective system?
Will it even work?
Are there any issues?
Can this cause a problem?
Thanks
Can I use them both: YES
Does it make a better protective system: Perhaps. read notes at bottom
Will it even work: YES
Are there any issues: NO
Can this cause problems: NO
Notes:
First there are "Surge Protectors" and there are Surge Protectors. Most of the devices sold today as Surge Protectors are really SPIKE supressors. not at all the same thing.. SOME, like the Progressive Industries HW-50C (or HW-30C) or the TRC "Surge Guard" competing products. or the portable versions of those (Far as I know these 8 are the ONLY ones) are true Surge protectors. If the voltage goes high (or low) or the frequency goes high (or low) they shut you down to protect you, Plug into a 30 amp outlet that is 240 volt and they shut you down to protect you IN addition if power "Blinks" (say goes off for one second) they hold you off for a while so as to make life easier (And longer) for your air conditioners. IN the case of the HW-X0-C models it may be only 15 seconds (not long enough) less you clip the jumper to make it nearly 3 minutes, the rest are 3 nearly 3 minutes (Minimum recommended OFF time).
If you have two of these, in series, the ONLY thing is the delay before you power back on in a power fail situation is longer. This is never a problem.
Now, the other type of "Surge Protector" (note the quotes) is nothing more than MOVs (Metal Oxcide Varisistors) these devices are very high impedance (resistance0 normally but once the voltage goes too high (Spikes) they become very LOW resistance, clipping the spike and saving the down-line electronics.. They DO NOT however protect against long term over/under voltage, Plug into that 30 amp 240 volt outlet they blow like firecrackers. (Been there when it happed, Not my problem though) Also not an RV).
They do not monitor Frequency either.
I have that type of "Surge Protector" hardwired to my breaker box
And the plug in model outside.
