kwplot34
Aug 26, 2016Explorer
UGGGHHH...........
If these rv manufactures would put a trash can and a shop vac inside the unit when they are building them it would save a lot of head aches for everyone.
2016 Thor Chateau 31L, purchased new in June, and this is the 2nd time I had to call Thor about an electrical problem, and each time its due to the trash they leave behind.
This time it was the heater blower motor, it would turn on when you connect the battery, wall control is in the off position.
Called Thor to help diagnose, and I explain to him about the trash they leave behind and already had one problem from it. The Tech tells me to pull the outside cover off to turn the switch off out there, As im pulling the cover I am explaining to him about the trash I find, finish pulling the cover off and there it is, saw dust piled up un the control board, blew it off and works now. Unbelievable.
