GHOST1750's avatar
GHOST1750
Uneven tire wear
Need some ideas on why my right front tire is wearing on the outside of the tire? rest of the tires are wearing smoothly. I have a Spartan chases.
  • Absolutely, with an IFS, have front end alignment checked. Hopefully by a shop that can give you a BEFORE and AFTER printout.
  • wolfe10 wrote:
    What chassis?
    Solid front axle or IFS?
    Independent front suspension Spartan Chases.
  • is it a goodyear G670 tire?
    Can you post a picture of the wear on the tire?
    THis https://dl.dropboxusercontent.com/u/201045551/Forums/PhotoUpload/RV.NET-Photo-Upload.html will let you easily post pictures here. I use onedrive, or iCloud, I take a pic and its on my laptop within moments, bing bang boom, pic is on this site.
    Goodyear G670 tires are prone to "rivering" which is when 1 tread line on the tire (could be anyone, outside, inside, middle) wears quicker than the others. You can tell by looking at it, wear caused by alignment problems shows a pattern, rivering, the tread is just gone.
  • Had our alignment checked at Brett's truck parts and service. We have a Spartan.. They work on front ends of trucks and RVs.
    916 928-3818
    We thought they were great...
  • Alignment issue would be my first thought. Did this just start to happen? When was the last time the front end was aligned?
  • I think there is a Spartan place in Sacramento. I thought about calling the fire department to find out where they get the fire trucks aligned.
  • As stated it is an alignment problem. Easy to get fixed BUT you need to find someone who knows how to do the alignment on a Spartan chassis. Many (most) places do not and if they do not know will screw it up. Been there done that. Have a friend that had a bad experience simply because some mechanic thought he could do a alignment and probably could, just not on a Spartan chassis.
  • http://www.procarcare.com/includes/content/resourcecenter/encyclopedia/ch25/25readtirewear.html
    as stated an alignment issue.
