goufgators's avatar
goufgators
Up date on problem posted a couple weeks ago...
Earlier, I posted a problem with the electrical outlets being 'dead' that powers the front and back t.v.'s. I received a number of suggestions and I thought I had followed each in an attempt to resolve the problem. One suggestion was that it might be a tripped ground fault breaker on the inverter. I 'thought' I had checked that and found it not to be tripped. Soooo, I finally took it to CW and turned the problem over to them. Well, the problem was a tripped breaker on the inverter. I obviously did not properly check to see if that was the problem. Cost: $148. to reset the breaker. Lesson learned!! Thanks to all who 'tried' to help me. Next time I'll try to follow suggestions a bit more carefully...
