atarsha
Jun 19, 2014Explorer
woodgeezer wrote:
You don't say what chassis you have, but I would have the drive shaft professionally checked. I experienced a similar "rattle" on two Fords I owned and had a warn rear u-joint on one and a bad center bearing on the other. Just checking the fit by hand is not the same as doing a fine inspection without load. Cheap check and easy repair.
It is the 2003 Ford E450 Cutaway Chassis, I'm not sure if that's the detail you're looking for? Also, where might I take a 31 foot RV to have that checked? A general mechanic, an RV dealership? (Especially considering we're living in it now.)
38,705 PostsLatest Activity: Jan 24, 2025
