Cooncatz's avatar
Cooncatz
valve stem points inside on rear dual tires?
I purchased a 98 Four Winds Class C in December and it has been parked since I brought it home. The snow is about gone so I wanted to check the air in the tires; but the valve stem on the rear outside tires are pointed inward and I can't see the stems on the inside tires - I assume I will have to crawl under the unit to check them.
Is this unusual - are the tires mounted incorrectly - is there a fix for this.
thanks
