We took our our Coachman 32 BH Freelander today for a trip.I dewinterize it and fill the water tank.I am noticing very low water pressure in all the faucets.What could be the reason.Any help would be ...
You should check to see if you have good gravity flow from the fresh water tank. Some debris could be blocking the connection. Take the output side of the pump loose and see is you get good flow. Look for a strainr on the pump input side. I doubt whether it is the pump.
