GollyCollie's avatar
GollyCollie
Water Leak Monitor
My wife and I have a 2013 Leprechaun 317SA that has been very prone to water leaks in the cab over section. This is an issue we have fought for over a year now. I am finding that water leaks are a very common problem in Leprechaun's so I wanted to pass this tip along to others in my boat. Every time it rained I found myself heading out to the motorhome to inspect the cab over area for water leaks. Where water tends to collect on the Leprechaun is inside the front cap, and that area can be a pain to get to so I wanted to find something to find an easy way to keep an eye on the area.
I looked around and discovered an inexpensive monitoring system called the GE Choice Alert Wireless Alarm System. This is a very simple alarm system that has a number of monitoring devices that work wirelessly with it, and one of those monitoring devices is a water leak sensor, so I ordered the base unit ($35.36 on Amazon) and several of the water leak sensors ($11.59 each on Amazon). I installed two of the wireless water leak sensors inside the front cap of the Leprechaun and paired them to the base unit which took less than 30 minutes including reading the instructions. As a bonus, the base unit comes with one door sensor that I mounted on the motorhome door. Since the motorhome is parked about 20 feet from my bedroom, I placed the base unit there so we can hear it in the house. When we are on the road I simply put the base unit in the motorhome. I did this install about two months ago and it has been silent until last night when we had a very hard, driving rain. About 10:00 last night the alarm went off and I went out to inspect and discovered a very small amount of water inside the front cap, a few tablespoons at most. I was able to find the water and dry it up before damage could occur. I think that the water was able to get inside the cap through one of the marker lights because of the way the rain was blowing.
So for about $60 I was able to prevent a possibly very expensive repair and I can find and fix the water leak. I also purchased several more water leak sensors that I haven't installed yet. I am still figuring out where I want to put them. The sensors operate on lithium batteries that they say will last up to two years, and when the batteries in a sensor get weak the base unit detects a low signal and lets you know about it. These are a really neat, inexpensive way to monitor a water leak issue.
