Hey everyone. Getting back to my water leak I have now removed the shower, the vinyl flooring and the washer dryer that is located in the kitchen slide. I could not find a leak anywhere that was obvious. No water damage in the slide or under the shower. The plywood in the middle of the floor between the fridge and slide was completely saturated through. I removed the wet plywood and only found styrofoam insulation. As there are no water lines of ant sort in this area does any one have any ideas where the water would be migrating from?
