cableguy574's avatar
cableguy574
Water Leak
I need to remove the right side exterior panel to get to my gray water flex pipe. It is on a 2008 National Pacifica 36A Has anyone done this
  • Never remove any rear skin if not absolutely necessary. You'll be in a world of hurt. Do it from the inside or bottom.
  • drop the tank, yep might have to cut pipes to get it down, but can use repair sleeves to put back.
  • If you're talking about the exterior skin, that is usually bonded, (glued) so it most likely will get destroyed trying to remove it....Dennis
