Dutch_12078
Jul 25, 2021Explorer II
If you have a use/fill selector valve or similar, make sure it's fully in the correct position. The other possibility is a faulty check valve in the water pump that's allowing city water to leak back through the pump into the tank. The tank drains and vent/overflows sometimes share the same outlets or are very close to each other.
38,708 PostsLatest Activity: Mar 06, 2025
