capacitor
Jul 25, 2021Explorer
The pump has a check valve to keep water from going to the fresh water tank. It sounds like it is bad and allowing water into the fresh and out the drain. Fill the fresh tank and use the pump and no city water for this trip
Edit: the two valves you mention are probably the low point drains for both hot and cold. Close them.
38,708 PostsLatest Activity: Mar 06, 2025
