30sweeds
Jul 05, 2021Explorer
I don't think there is a tank drain.You have to pump the water out. Your water tank is probably full and the water running out of the bottom is from the tank over flow. Figure out which way you need to turn the valves to make the pump operational,drain the tank if you want,leave the valves where they are,hook up the hose and you will have city water.
38,706 PostsLatest Activity: Feb 01, 2025
