Jun-16-2015 06:58 AM
Jun-16-2015 09:04 AM
Ivylog wrote:
On a good certified truck scale the four leg analogy above is not correct. The error will be less than 50 lbs.
Jun-16-2015 08:49 AM
Jun-16-2015 08:45 AM
Jun-16-2015 08:24 AM
rgatijnet1 wrote:
The most important thing about weighing all four corners is that the coach must be level and not leaning in any direction. Most scales that you drive up on, even if there is room to the side, do not allow you to be level so the weight is of little use. If the coach leans towards the scales, the weight reading will be too high. If the coach leans away from the scales, which happens the most, the weight reading is too low.
Jun-16-2015 07:42 AM
Jun-16-2015 07:11 AM
Jun-16-2015 07:07 AM
