Grit_dog
May 24, 2023Navigator
Valpo Camper wrote:
Sorry for the old thread posting. So what weight limit jackstand would be best for the front of a class C? I need to jack up the front to look at my front brakes. I have a 10 ton bottle to lift it just not sure how much hold capacity I need to support it. I have car stands on hand that will hold 2 tons each so if I can lift it then set both on the side I am working on then I should be able to support 4 tons.
If you think you can set 2 jack stands side by side and leave the other front wheel on the ground, you may have failed pre school and the square block round hole test.
I’d suggest staying away from things that may injure you.
PS it’s ok to bring the thread back up. It was a weird one anyway….always fun when Baja Man posts!
