FireGuard's avatar
FireGuard
Mar 29, 2014
wheelbase consideration and motorcycle lift
Is anyone using one of the motorcycle lifts on the rear of their MH? If so, how does it work and what size is your MH.
I'm talking about the elec or hyd model that will carry a full size touring bike and still allow you to flat tow a dinghy.
Aside from the normal GVW and axel rating is there a wheel base minimum or formula that works. I'm assuming you would be looking at a minimum off 800 lbs or so depending on the bike.
I'm sure the longer the better, but how would a 34-36' MH work?
