rvhavingfunyetT
Nov 17, 2017Explorer
Where to buy fuel tanks (80-85 gal)
I just acquired a 1996 Fleetwood Southwind 34L based on the Chevy P30 chases. I pulled the fuel tank out today and want to attempt to clean all the gunk and rust out as it has been sitting in a field for 7 years. My thought was to put a cleaning mixture inside to try and remove the rust and gunk. I've seen people use everything from muriatic acid diluted with water, to vinegar, etc., then pressure wash it. My biggest concern is making sure I can even drain the tank completely. IE...I removed the sending unit and turned the tank upside down to try and dump out what fuel was remaining (around 7 gallons), but it's not that easy getting it all to drain out.
So, I am all ears if anyone has some tricks to completely empty out the tank...or if they can point me in the right direction to buy a new tank.
Thanks
Thanks
