VA-Apraisr
Mar 05, 2020Explorer II
White-Rogers thermostat issue.........WARNING!
Posted awhile back about thermostat issue in my C. They installed a White-Rogers unit that doesn't have a separate on/off switch...you just move dial to left down to 50 degrees and hear a small "click". Well, in January, with unit in the OFF position, temps went down into the 20's and guess what - furnace turned ON and used all my propane! Heard the blower motor whirling away and pulled the furnace fuse to shut it completely down. Took back to RV service and they weren't sure it was the wall unit. Next day they called and said they had 3 other clients call with the same situation using the same White-Rogers! Furnace was turned off but when temps went below the 50 degrees setting on unit, furnace came on! They replaced the thermostat with another brand. Just a FYI.
