โNov-23-2013 01:49 PM
โDec-26-2013 08:13 PM
FIRE UP wrote:Skid Row Joe wrote:Supercharged wrote:
I carry a 250 cc scooter.
What type of set-up carrier did you go with, Superchargerd?
Do you use a cover on the scooter, or leave it in the elements?
The Honda Ruckus is the size scooter that I am zeroing-in on for a quick hop to the library, grocery store or Walmart wherever I'm parked.
I used to carry a TW 200 Yamaha on this hauler that I built. Too bad you're too far away, I'm going to put this one up for sale 'cause it just doesn't get used any more. It's got a receiver on it too for towing while hauling. It worked flawless.
Scott
โDec-26-2013 05:53 PM
โDec-25-2013 08:38 PM
โDec-25-2013 08:26 PM
dan23 wrote:
I'll add my two cents because I solved the issue of carrying a motorcycle with me a bit differently than any of the posts so far. The closest is the guy who carries a scooter.
At first, I looked at power lifts and decided the weight with mc and cost of the lift seemed silly and unworkable, so I rejected that solution.
Then I looked at trailers and nearly bought one, but decided against it because of the hassles of towing, plus pretty much always needing a pull-through site... rejected that idea, too. Extra size can quickly shut you out of your preferred camp grounds if you're not careful.
Then one day I was looking through on-line ads and found a nice used Kawasaki KLR for far less than the cost either a trailer or a lift, and bought it. Then I got a 600 pound rated carrier that cost less than a third of either a lift or a trailer. I sometimes pull the front of the mh up on a block to lower the carrier so it's easy for my wife and me to push it up and tie it down. Problem solved.
In addition, I now have another choice of motorcycle, and more choices of where to ride, etc. and have not had so much fun motorcycling since my high school days when every manufacturer sold a version of so-called street-scrambler motorcycles. It's a lot easier to find low-traffic areas to ride and KLRs are famous for ease of care, eliminating the need for a cover when transporting it, although I do cover it in camp.
Everyone will have their own opinion on this, but to me, possessions can possess their owners and trying to carry one of my other motorcycles would leave me in that situation. Which is why I do without slides and a towed car, too.
โDec-25-2013 02:00 PM
Flanz wrote:
Fire....Since you did buy one, did you use it while travelling with the MH?
If so, how did it work out? Did it create any issues/concerns to the MC while in motion? I know you said it "touched" the MC, but overall did it perform okay and cause NO damage to the MC?
Was it just the fact that it was advertised that it wouldn't touch the bike an issue?
Just trying to become informed....
โDec-25-2013 09:19 AM
โDec-25-2013 08:16 AM
Flanz wrote:
Hello,
I'm also leaning towards a Hydralift to carry my Road Glide Ultra. Looking around at this moment for a used.
Someone mentioned covering the MC while travelling. Hydralift offers an enclosure that can be used while driving and at the campground. Although I haven't really looked at it it may be an option.
http://www.hydralift-usa.com/accessories/enclosure/
Comments?
โDec-25-2013 06:19 AM
โDec-22-2013 09:22 AM
โDec-22-2013 05:05 AM
โDec-21-2013 05:33 PM
โDec-21-2013 04:27 PM
โDec-21-2013 03:08 PM
FIRE UP wrote:
Tim fm ct,
Well Sir, this is a bit of a tough one. You see, in an enclosed trailer, it's not problem because, when you tie it down, the tie downs do not get in the way of a cover because there's no need for a cover INSIDE the trailer.
But, when you tie a bike down, either on a lift, like what I and many had and presently have, and or, inside the back of a pickup, the tie downs get in the way of really cinching down a good cover. Ultraguard makes a travel cover that has multiple straps, buckles, gathering points etc. that really make it snug to the bike. It even has little "slits" in it for possible places to run "some" tie downs through it.
Well, that's perfectly fine if, IF, your tie downs just happen to be placed on the bike and, tie to whatever you're tying to, in just the right spot. But, as in our case, they (all 6 tie downs) were no where near the slits provided so, that makes for a very difficult time to really "seal" up a bike to keep it from the elements/dirt/debris/salt/rain/ etc.
That cover, is by far, the best travel cover made. It's about as thick as a real good sleeping bag. And, it conforms to multiple, normal protrusions like the windshield, handle bars etc. And because of the multiple buckles and cinch points, it really CAN snug up extra tight so there's no possibility "etching" of the paint. This is not a flimsy "throw over" cover just to keep the sun off. This cover means business.
But, if one gets one of these covers, then a good upholsterer is needed to "fit" that cover on your bike, with tie downs in place so that appropriate slits can be inserted and then "Button hole stitched" to keep them from running or un-raveling.
The other problem is, even if you were to get that Ultraguard cover and, have it modified to accept all your tie downs, the problem is, install it and working with it in the confined space(s) between the bike and the side beds, and front. I know because I tried it. Other than an enclosed trailer, it's pretty tough to really seal a bike, especially a large cruiser, i.e. Goldwing, Harley Street or Ultra Glide, Yamaha Venture full dresser and more to the point that there's no possible infiltration of the exterior elements and contaminates. Good luck.
Scott
โDec-21-2013 01:39 PM
