goots
Apr 04, 2015Explorer
window opened
Is it alright to have a window opened by the sofa area when traveling down the road or dose your mileage drop??
valhalla360 wrote:Healeyman wrote:TucsonJim wrote:Harvard wrote:
The open window may cause the water traps in the sinks and shower to burp foul odours.
I'd sure like to understand the scientific reasoning behind this comment.
It's called Bernoulli's Principle. (Google it)
As a vehicle moves through the air, the air moving past the sides/walls of the vehicle create a partial vacuum and will draw air out of the vehicle through any opening.
Evidence of this is that smokers usually slightly open a car window to draw the smoke out of the cabin.
If inside air is being sucked out of an otherwise sealed RV, air will be drawn in through any opening that is of a higher pressure, such as the waste tank vent pipe on the top of the RV.
In it's journey to get to the open side window, the sucked-in air will travel through the waste tank(s) and bubble through the sink and shower "P" traps and into the RV.
In MY RV, when a window is partially open, the door in the vent hood over the stove rattles like the dickens.
Tim
Nice theory but unlikely to have the proposed end result.
- Your vent pipe has the same principal pulling on the other side.
- The pressure difference would have to be fairly dramatic to clear the P-trap.
Reality is as long as it's not a dusty road, there should be no harm and likely not noticeable MPG change.
1492 wrote:
I think that since your motorhome was never designed to be especially aerodynamically streamlined, and is creating significant amount of drag already, an open window is not going to make any type of noticeable difference in mpg.
glkids2 wrote:
Yes all tanks have vent stacks otherwise the waste flowing into the tanks would essentially hit air dams flowing in and would not drain
Tim
Tim
