windshield washer motor
Old_Blue
I have a 2007 Holiday Rambler Neptune and for some reason the windshield washer just does not work. First I saw that the
wires had come unhooked, took care of that, than still nothing.
With the washer switch on, there is 12volt to washer, then unhooked
rubber tube near front nothing no fluid, so maybe the motor is
shot,,so is it easy to remove motor and replace?? Is the motor
something that AutoZone or NAPA would have? any help would be
greatful for..
Bill
Bill
36 Holiday Rambler
Harley Rider
4 REPLIES 4
Old_Blue
Well it came out easy, looks like water got into the motor, some way, and it is toasted,,,
will have a new motor tomorrow,,,,thanks for the reply
Bill
Bill
36 Holiday Rambler
Harley Rider
crasster
yes, the pump should be simple. You could probably even find one on Ebay that is inexpensive.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
midnightsadie
auto stores have universel pumps.
Matt_Colie
Bill,
Little washer pumps are easily gotten.
Have someone hit the switch while you listen. If you can hear it run and nothing happens, it probably got run dry and it is toast.
Just be sure to check that what you have is getting power.
Check the hose to it before you go to far, because if it is cracked, the pump will suck air and self-destruct in short order.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
