scbwr wrote:
The Intent is a budget level motorhome and as such, you need to compare it to other options. In our search for a gas class A, we looked at a Winnebago Vista which is a little more expensive than the Intent and we could see that they aren't comparable to a smaller class A made by Tiffin or Newmar or even higher quality models such as the Winnebago Adventurer.
Before making a decision, take some time to look at a few smaller Tiffin, Newmar and higher grade Winnebago motorhomes. Then it becomes a personal decision based on your budget, how you plan to use the motorhome and how long you plan to keep it. Although I really like to buy new, when it came to our budget, we opted to buy a higher quality used rig that we plan to keep for quite a few years.
If you are going to take a lot of trips and cover a lot of miles and spend a lot of time in your RV, I'd suggest buying higher quality with more features. If you're just plan to use for weekends and an occasional longer vacation, the Intent may work very well for you.
Good luck in your search....just take your time!
My search is for a 24-26ft MH. Most of what I see in that range is C's or B's. What higher end A's exist in that length?
