opnspaces
Jun 30, 2023Navigator II
Is the leak at the joint from the white pipe? When you tightened the screw type hose clamps did you use a small ratchet and 1/4 inch socket? If just tightening with a flat blade screwdriver it's probably not tight enough.
38,709 PostsLatest Activity: Mar 09, 2025
