Harvard
Feb 05, 2018Explorer
Hi JD.
For the record, get a set of Ingalls 594s and "RubixCube" them to be +2.0 Degrees Caster and 0.0 Degrees Camber. Pull one wheel at a time and install them. Then set the toe to be 0.125 Toe In and you are good to go. That's what I did in an RV parking lot in Wellton AZ without the benefit of the hind sight I have now, 7 years later... I am not an engineer but I will bet my money on the engineering specifications that put all this hardware together in the first place.
38,705 PostsLatest Activity: Jan 20, 2025
