vonkal's avatar
vonkal
Yet another tire pressure question.
I could use some verification of the tire pressures for my motorhome. I think I have this right, but I sure would like someone who knows more to confirm if I do.
My coach is a 2002 Monaco Diplomat 40’ with three slides. As I cannot find a location to do corner weights yet, I have just used a Cat scale to measure the axle weights.
The GVWR on the coach is 32,000 lbs
Actual Weight
Weight with full fuel and water with two people onboard = 28,635 lbs.
Front axle = 11,185 / 2 = 5,593 lbs per tire
Rear axle = 17,450 / 4 = 4,363 lbs per tire
I pasted below what the Goodyear chart showed. The chart I found this info on can be found here http://www.goodyearrvtires.com/pdfs/tire-care-guide.pdf
Goodyear 275/70R22.5 load range H
PSI 85 90 95 100 105 110 115
Singe 5170 5400 5630 5850 6070 6290 6510
Dual 4770 4980 5180 5390 5590 5800 6000
Now, using the above chart, I have concluded that my front tires should have 95 psi, and my rear tires should have 85 psi.
After reading in forums, these pressures seem low? Most seem to be running in the 100-110 psi range?
Can someone advise me if I have interpreted the Goodyear chart correctly, and these seem to be the right pressures for my tires?
(Sorry, I can't get the formatting right to display the chart info.)
Thanks
