ibycus's avatar
ibycus
Grills propane quick connects..
Hi All.. Question about the quick connect on my new RV..
I've been looking for a Grill that will connect to the quick connect system on my RV, but I'm not really sold on any of the low pressure grills. I found the articles about taking the regulator off the Weber Q series grills and putting a quick connect on it ..
I started looking around online for the parts and saw there's 1/4", 3/8".. the article I was reading was calling for a 1/8" MNPT fitting.. I'll be honest, I have no idea what those sizes are referring to.. are those internal diameter or external diameter..
I guess the bottom line question I have is, how do I know that if I buy a fitting, it will fit the quick connect? what size hose do I need? are they standard sizes and just the internal diameter varies.. or does the outside diameter vary as well.. and if so, how do I determine what size I need?
btw, I have a 2013 Dutchment Rubicon 2900..
Sorry if this has already been discussed.. I searched but didn't come up with any answers.. if it has and you can point me to the correct place, I'd appreciate it..
  • Ron3rd's avatar
    Ron3rd
    SWMO wrote:
    Well the Male National Pipe Thread is a standard easy to find fitting. Most large RV shops or LP stores can set you up.
    I might point out thought that I passed on using my connection. Not only is the hook up expensive, you are also bound to it's location. I have a 5# LP tank and a readily available hose that I can use anywhere. It last a long time on my Q120.
    On the Weber, when you remove the regulator, you're left with a 1/8" female pipe thread hole. In the past, you needed 2 fittings and Calore made a special fitting for the Weber noted in my link. I also bought the longest hose from Calore as they have several different sizes. The 1/8" female/female coupler noted in my link is a common part and is from from Lowes. The Calore hose is the most expensive part. I ended up spending about $75-80 with shipping as I recall. Works great.
  • Ron3rd's avatar
    Ron3rd
    Simple job on a Weber. I removed the regulator on my Weber Q to hook to my new trailer's quick connect.
    There is some disagreement on whether or not you need to remove the regulator, some report a low flame with the regulator on an other say it works fine. I went ahead and removed mine, you can unscrew it with your hand. Here's how I did mine with a parts list:
    WEBER CONVERSION
    Simple 10 or 15 minute job once you get all the parts rounded up.
  • Well the Male National Pipe Thread is a standard easy to find fitting. Most large RV shops or LP stores can set you up.
