Hard boiling fresh eggs
Stars101
I have never had good luck using fresh eggs for deviled eggs. The carton you buy in the store just makes a mess by sticking/breaking (even though I don't consider them particularly fresh!).
I found a fool proof recipe on a backyard chicken forum:
USE ROOM TEMPERATURE EGGS!!
Boil a large pot of salted water
Gently lower eggs into water - boil for exactly 17 min.
Remove from water and put in ice water bath for 17 min.
The eggs just slip right out of the shells. It works for farm fresh eggs or regular grocery store ones.
I'd never heard of this way to prepare them and just thought I'd share.
21 REPLIES 21
swtgran
I also use a pressure cooker, and use the same process, only mine is a stove top cooker, and I use the low pressure setting. Even works for eggs fresh out from under the hen.
If I want soft boiled I cook them 3 min. to 3 min. 30 sec., depending on whether I am using my tiny PC or the larger one. I then run the pot under cold water to stop the cooking.
I also poach mine in those little silicone tulip shaped poachers, in the PC. I do the them the same as soft boiled eggs and they are perfect every single time. terry r.
Swtgran
2007 Casita 17ft SD
2005 Toyota Tundra
jjjandrbaker
I use my electric pressure cooker. 6 minutes at high pressure. Then let thd pressure drop naturally. Shells peel off like gloves. Take them right out of the fridge- two dozen at a time.
Jim Baker
San Antonio, TX
travel blog and photos
denoel
Dutchman Sport: How long do you steam the eggs?
Fulltiming since 2010
2010 Montana Mountaineer 347TH
2007 GMC 3500HD Dually
2001 Harley FLSTS - (Heritage Classic)
LA Chock ( http://www.baxleycompanies.com/LAChock.html)
Honda 3000
Wanderlost
Nomad II
Nomad II
We have a dandy little microwave contraption that we use to hard cook eggs in the shell, or to make poached eggs. We follow the hard cook stage by placing the eggs in the shell in ice water. Both are cooked via steam, not by direct contact with water.
Very happy with it.
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -- Mahatma Gandhi
Czarny, black cat
Rainbow Bridge: Spotacus, Alexander the Grrreat, and so very many more
DutchmenSport
We never boil eggs any more. We have a double pot. The bottom pot is a normal pot. The top pot has holes in the bottom and sits inside the bottom pot, Put water in the bottom, but not enough to come inside the top pot bottom. Insert eggs in top pot, boil water. The eggs "steam". Been doing them this way for years and years now, and have perfect to peal eggs every time.
Little_Kopit
A) They should be "hard cooked eggs" , never boiled.
1. Use tap water warmed to its hottest.
2. Turn stove on to 1 mark above the 1/2 way mark.
3. Add eggs.
4. I leave them on for 22 minutes. This should have little bubbles, just below the boil point coming to the top of the water.
5. Remove from stove and drain.
6. Cover with cold water.
7. Let sit 5 to 10 minutes.
B) My aunt did the cold water start, and I don't think she boiled either. She also did the cover with cold water. Somehow I think this shrinks the egg in the shell.
C) My Aussie cousin told me in person down there last Dec. that she couldn't do hard cooked eggs. So, her late husband had bought her an egg cookers. The one she has now holds a dozen eggs, You put the cover on, plug it in and it cooks the eggs per manufactuers timer. She cooked enough eggs for my breakfast egg my first morning. I got one from the fridge and peeled each one as needed.
One would think if one looked around up here, that electric egg cookers could be found, should that be our preferred option.
........we're both in our 70s.......
:C
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
rv2go
This is how I do it.
Place eggs in a heavy-bottomed saucepan and cover them with cold water. Make sure the tops of the eggs are covered by at least an inch of water. How much water will depend on the size of the pot, but in general, a bigger pot is better. Crowding the eggs risks cracking them.
Bring the water to a full boil, uncovered, then remove the pot from the heat and cover it. Let the pot stand untouched for 17 minutes.
Remove the boiled eggs from the water and transfer them to a bowl of cold water for 15 minutes. Then either peel and serve or refrigerate.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
