wca01 wrote:
Well, if you really want good white bread, the following recipe produces the best I have ever had. Not that I include the tools I use, but if you use different tools you can adjust.
Good Baking!
Wil
Captnwil's Cuban Pan Bread
WCA Cookbook
Bread & flour
This is a variation on the King Arthur Flour Cuban Sandwich recipe and only makes the bread, not the complete
sandwich.
This recipe makes a normal loaf in a loaf pan for easy slicing the bread for toast or sandwiches.
You may use any tools and ingredients you desire, but this recipe was derived using:
Bosch Compact Mixer
Chicago Metallic 10 x 5 x 3 bread pan
Sharp Micro Convection Oven.
Using these tools and directions allow for making bread with no dishwashing necessary. The dough is either in the
mixer bowl or the bread pan. No hand kneading on any surface is required. You may need to lightly clean the dough
hook.
The bread is much better with lard than butter.
17 ounces King Arthur Bread Flour
4 teaspoons sugar
2 teaspoons salt
2 teaspoons SAF Red Instant yeast
3 tablespoons lard
or
4 tablespoons butter
1-1/4 cup lukewarm water
This recipe uses only two containers -- the Bosch Compact Mixer bowl and the Chicago Metallic bread pan.
Mix, then knead together all of the dough ingredients, in the Bosch Compact Mixer set on a speed of 2 to make
smooth, supple dough – 6 to 10 minutes.
As the dough gets ready the sides of the bowl will become clean and when finished the dough will climb and be
contained on the dough hook.
Remove the dough hook and allow the dough to rise in the mixer bowl until its puffy, though not necessarily doubled
in bulk — about 1 hour, depending on the warmth of your kitchen.
The Sharp microwave/convection oven has a "Slow Cook" function, and the temperature can be adjusted. set the
"Slow Cook" function to 100 degrees for perfect rising of the dough. The "slow Cook"
Let the loaf rise until its top is above the top of the pan – 30 minutes to an hour.
When fully risen, set the oven to “Low Bake.” No preheating need. Bake bread for about 20 minutes or until
internal temp is 200F -- not over! and the top is golden brown.
If using a conventional oven, preheat to 375F and bake for about 30 minutes.
Remove loaf from the oven, and cool on a rack.
"You are evillllllllllllllllllllllll!"said in a "I wish I was a baker" manner.
This summer I made cubano sandwiches for the kiddos' camping trip and mentally lamented that I was forced to use commercial Italian bread.
Once upon a time in NYC you could get Italian, French or Spanish (AKA Cuban) bread at the local corner stores and know the difference. There is something to say for and against the "melting pot" on that level:)
