ottor
Apr 18, 2014Explorer
1.Power inverter .. and .. 2. Wifi Extender - two questons
1) The only purpose I think I'd want an inverter for is to charge laptop/phones/Ipad. Don't use hair curlers or electric skillets, so .. IF my laptop charger says it uses 19.5v, 6.7amps, do you think a 300w inverter would be enough - or would this one be an overkill .. http://www.amazon.com/BESTEK-1000w-Inverter-Supply-MRI10011-1/dp/B007SLDDHQ/ref=cm_cd_ql_qh_dp_t
Also, this says it's to be attached to a 12v battery - perhaps a silly question, but I'm assuming it'd work on 2 6v batteries chained?
2) Camp quite a bit in a campground that has Wifi.. Problem is, a lot of the spaces are away from the signal source, giving me about 2-3 bars of signal. I'd like to get a Wifi extender with an external antenna - any suggestions based on first hand use?
