- Robin1953ExplorerHere are the requirements for the ViP211K receiver:
Choosing a compatible external hard drive:
• The hard drive must have a USB 2.0 connection.
• The capacity of the hard drive should be between 40GB and 750GB.
• Using a hard drive with an external power supply is recommended. External hard
drives powered by the USB cable may not function properly with your receiver.
• Do-it-yourself kits and expandable racks may not be compatible.
• Only hard drives that are single-disk units are supported.
• Dedicate the hard drive for use only with the receiver; do not use the drive for other purposes, such as storing computer files.
If you have the newer ViP211Z you need to check the USB connection, it may require the newer 3.0 USB connection. Also it may allow a larger hard drive. As you can see above the 211K can only deal with a hard drive from 40GB to 750GB. As others noted that once you have it connected just call Dish and tell them you need to have the DVR option turned on for the 211 and it was $40 when I did it a few months ago. HTH - want-a-beExplorerWe have the 211 receiver and our hard drive does not have a 120 volt power source.
- lbrjetExplorerAlso must be USB 2.0 compatible. We have a 2TB Seagate 3.0 that is 2.0 compatible. Works like a charm. We have the 211Z receiver.
- BB_TXNomad
K Charles wrote:
You need a hard drive and a one time payment of $40.00
X2. I believe Dish says the external hard drive needs its own power, i.e. its own 120 vac power cord. I bought a Hitachi hard drive from dishformyrv.com when I bought my 211 receiver from them. - K_CharlesExplorerYou need a hard drive and a one time payment of $40.00
- BumpyroadExplorerI am interested in this myself.
bumpy
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
