ZaBigD's avatar
ZaBigD
Can't find a coaxial selector switch in my RV
In my 1990 Fleetwood Flair my TV antenna works very poorly. I cannot find a selector switch between over the air TV and cable. I had the same type batwing antenna on my last trailer which worked excellent that had a selector switch. Parked in the same exact place, now I receive terrible reception. I haven't tried hooking up to cable yet. Anyone know if there is a hidden selector switch or have any suggestions to improve both over the air and cable reception. I would imagine without a selector switch the signals would interfere with each other.
Thanks in advance.
  • You don't need to replace the whole antenna just buy the little piece that comes out from the side called the wingman. Easy to add to the original antenna.
  • ZaBigD wrote:
    Thanks everyone for helping. I will try replacing the old batwing with the newer type (top only) along with the exterior coaxial cable. Anything beyond that is above my pay grade! I still can't find a booster (Button) anywhere, nothing is around the power source, antenna feed or elsewhere. TV's are digital also. The diagram is helpful and Thanks again.
    You cannot run a coax directly from the antenna to the TV. You need that power supply between in order to get 12V power to the head of the antenna. Do you have a switch box with a bunch of buttons such as ANT, Cable, AUX, etc? If so, the power supply may come from there. Otherwise you will want to look for a wall plate with a tiny button or slide and a light that comes on and off or look in a cabinet up front for a silver box with 2 12V wires and usually a toggle type switch nearby to turn power on and off. Can you trace a coax from the back of a TV backward to see if it comes from some kind of a power source? You might have to try from both TV's as the power supply only needs to be on one line ahead of a splitter.
  • wa8yxm's avatar
    wa8yxm
    If this is an older RV odds are the coax (roof top to antenna) is aging, also the connection at/in the roof may need renewal (mine did a couple years ago).
    THe switch is somewhere,, but other than the drawings above, I can't help you find it.
  • Thanks everyone for helping. I will try replacing the old batwing with the newer type (top only) along with the exterior coaxial cable. Anything beyond that is above my pay grade! I still can't find a booster (Button) anywhere, nothing is around the power source, antenna feed or elsewhere. TV's are digital also. The diagram is helpful and Thanks again.
  • RoyB's avatar
    RoyB
    This is what the modern day BATWING antenna looks like. It has the dipoles on the front of it that points to the local town for Digital HDTV signals...
    Google image
    This is the control panel for the BATWING antenna. Does not use a TV selector switch like the old ones did...
    Google image
    Point the antenna towards the local town that has Over-The-Air HDTV signals...
    Follow the instructions on the above pictorial...
    Don't forget to go to the Digital TV main menu and scan for digital TV signals first... You have to be using the newer HDTV digital TV sets now... Mine is one of the VIZIO Flat screen TV's from WALMART...
    When using the OTA BATWING antenna the PUSH BUTTON on the ANT PANEL has to be ON...
    Should work like gang busters...
    Roy Ken
  • Is there a booster switch for the antenna? Usually near the cable connector around the TV somewhere.
  • So does this 1990 RV have a newer TV? Unless it has a digital tv you won't get squat. Have you checked where the tv is connected to for the power button?
