โJan-05-2018 11:42 AM
โMar-02-2021 08:02 AM
โJan-06-2018 08:52 AM
sheltieRV wrote:Thanks!
...Battery (gasser) will run down after a few hours. I now put a trickle charger on it...The trickle charger cannot keep up with the discharge rate, so I am still limited to a few hours (a movie) before giving the charger time to catch up...
โJan-06-2018 08:02 AM
sheltieRV wrote:
I have been using this for about a year on my 16 silverado.
1. Battery (gasser) will run down after a few hours. I now put a trickle charger on it when I know I won't be driving for a few days (we are 3 months at winter location and I only drive about once a week). The trickle charger cannot keep up with the discharge rate, so I am still limited to a few hours (a movie) before giving the charger time to catch up.
2. I manually turn off the headlights (rotate dial counter clockwise all the way), as I found that the system will turn the headlights on if it gets darker and thus run the battery down even more.
3. I also keep a velcro tag on my RV door to remind me that the hub is on.
4. The silverado will start beeping at you when the battery gets low, get tuned into a chime ding and turn off when it happens (the first time I heard this I thought it was my neighbor and not me).
It is a bit of a PITA, but the price, bandwidth, and speed is worth the PITA when RVing.
โJan-06-2018 07:05 AM
โJan-06-2018 06:35 AM
joebedford wrote:Thanks! At least it gives me a timeframe to work with.
It took the batteries down in under 8 hours - I don't know the exact time.
Having the rig and truck plugged in while using the internet has never happened for us. Either we have had park internet or the sites were too short to stay hooked up.
โJan-06-2018 06:26 AM
trailertraveler wrote:It took the batteries down in under 8 hours - I don't know the exact time.
How long did it take to drain the batteries? Have you tried leaving the truck connected to a trailer while connected to shore power or generator? I was hoping the trailer charger could keep up with the hotspots battery drain.
โJan-06-2018 04:34 AM
joebedford wrote:How long did it take to drain the batteries? Have you tried leaving the truck connected to a trailer while connected to shore power or generator? I was hoping the trailer charger could keep up with the hotspots battery drain.
If you leave the key in accessories position, the hotspot stays on. However, unless you're charging the battery externally, it will go flat pretty quickly. Ask me how I know - I flattened the batteries in my 3500HD three times by mistake by using the internet hotspot.
โJan-06-2018 04:31 AM
jerseyjim wrote:If you don't know. Why answer? I am not asking about contacting OnStar. I am asking folks about the internet hotspot that is now in some GM vehicles. It is on the AT&T network so may provide better access in areas where my Verizon phone has no or poor signal.
I donno.....surely I am out of touch with this kinda technology...You want ON-STAR ? Simply push the (blue?) button the mirror.
jerseyjim wrote:I do not drive 70, rarely over 60 when towing and prefer to stay off the interstates. I am not even talking about using the internet while driving, but rather when parked in a campground or boondocking to provide an internet connection in the trailer.
...i thought a Silverado was for DRIVING...or are you one of these folks that runs 70mph and isn't paying attention?
โJan-06-2018 02:23 AM
โJan-05-2018 03:54 PM
โJan-05-2018 01:32 PM
ScottG wrote:
On the battery question, yes, the TT converter will keep the trucks battery charged while everything is plugged in.
โJan-05-2018 12:11 PM
โJan-05-2018 11:57 AM
We just got a Silverado with the GM hotspot. I have connected to it from the trailer using my Ubiquiti Nanostation connected to either the laptop or a Wifi Ranger Go2 and then two laptops connected to the Go2 by Ethernet. The speed was better than what I generally see with my Verizon phone tethered to the Go2.
On my Silverado, with the key out of the ignition, if I push the on button on the radio, the internet connection/Wifi will come on along with the radio. I can mute the radio, but have not figured how to turn it off and leave the internet/Wifi on. Is this possible? I also am not sure how long it will stay on as the longest I have tried so far is about 20 minutes.
The hot wire in the GM 7 pin connector stays hot when the ignition is off. I have read several discussions about trailers drawing down the tow vehicle battery if the trailer is left connected when not plugged into shore power. I am wondering if the reverse would be true that the trailer's charger would keep the tow vehicle battery charged when plugged into shore power while using the hotspot? I am aware of the issues involved with the tow vehicle charging the trailer batteries while underway that are related to wire size and length of run. I have no idea how much the hotspot draws.
Any comments and experiences would be greatly appreciated.
