SRT's avatar
SRT
Larger font sizes
OK, I've searched this forum for the key strokes to make the fonts size larger. No finds. I know someone answered the question earlier this year.
Thanks.
SRT
  • Old-Biscuit wrote:
    And if that doesn't increase it enough......
    Then hold down control key (ctrl) and tap 'plus' key (+) until it is as large as you want
    This is what I was looking for. Thanks!
  • "In similar fashion, you can select the Settungs tab of the abovememtioned menu, and set the screen resolution lower than it is now "
    Lower res, like 800x600 vs 1024x768, gives much larger fonts everywhere
  • wa8yxm's avatar
    wa8yxm
    path1 wrote:
    Look right on this page at lower right.
    "adjust text size"
    You will have to SCROLL down to the bottom of the page.
    You can also try CTRL + and CRTL - But that works on the entire page, NOT just the text.
  • To increase fonts on entire PC, in XP (similar in W7 and 8), go to Control Panel>Display, and in the Appearance tab you can select Normal, Large, or Extra Large.
    Also in the Advanced button of the Settings tab, you can set the DPI to large - this makes the fonts larger in system popup windows like Clock, Task Manager, Display, Wireless, etc.
  • Ctrl + increase
    Ctrl - decrease
    Ctrl 0 reset to default
    Also if using Firefox Select View/Zoom and Text only. This will increase only the text - not images. Makes for easier reading keeping everything on the page visible.
  • Or....If you are using a mouse with a roller, just press down on the Ctrl key and roll the wheel.
  • While holding down the 'Ctrl' key, hit the '+' key a few times until the font is at the desired size.
    To return to 'normal' hit 'Ctrl' and '0' (zero) at the same time.
    Easy as 3.14159265.
  • And if that doesn't increase it enough......
  • Look right on this page at lower right.
    "adjust text size"
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
