CHARLIE_B's avatar
CHARLIE_B
NEED SONY 4 PIN VIDEO PLUG
I need a SONY 4 pin(MALE) video cable end/cable to fix my back up/reverse camera. Anyone have a source all I need is the plug and 3'of the cord
HATE TO BUY A CABLE 66'LONG FOR $90+ JUST FOR ONE LITTLE PLUG
THANK YOU FOR YOUR HELP THIS IS MY 2ND POST
ILL TRY EMAIL AGAIN
weldor6284@gmail.com
weldor6284@mypacks.net
  • http://www.markertek.com/Connectors-Adapters/Video-Connectors/7-PIN-EIAJ-Camera-Connectors/Hirose-Electric-USA-Inc/HR10A-7P-4P-73.xhtml
    http://www.rvcams.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=RBCARVS&Product_Code=VCB-AV12&Category_Code=99
    http://www.rvcams.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=RBCARVS&Product_Code=VK-1PG&Category_Code=99
  • IT IS A SONY SPECIFIC PLUG
    THE PINS ARE VERRY SMALL IN DIAMETER .7mm.
    The cable is sold as vk-120A OR
    vk-320A for the heavy duty one designed to be mounted exterior of the coach.
    The BODY OF THE PLUG IS aprox 3/8" diameter and has a "key" that aligns the plug to the jack on the monitor/camera.
    I would like to make a "jumper cable" to use the SONY monitor without modifying the input jacks.
    Thank you for your input.
    CHARLIE_B
  • Look closely at your connector for manufacturer. Allied has many connectors and decent customer service.
    Allied
  • Don't know where you are, but if there's a Radio Shack near you, give the guys behind the counter a try. I've always found them most helpful when trying to solve "connector" problems.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
