boston blacky wrote:
An upgrade to (M.2 SSD) sounds doable. Question - do I need to 'format' and then install Windows once the conversion is complete? If so, what version of Windows is recommended? BB
If you are going to upgrade your drive with a M.2 make sure your notebook supports the M.2 format.
Before doing any upgrade, you may want to do a fresh system restore. Most computers have a procedure to restore to a factory fresh condition. The original OS is stored on a hidden partition of your hard drive, so if you replace the drive, this partition is gone. If you want to install a new drive, you could make an image of the old drive using software such as Macrium Reflect. A free version is availble at:
https://www.macrium.com/reflectfreeI have a 7 year old Toshiba Portege that I set up to dual boot between Windows 7 and Windows 10. I seldom use Win 10.
My system:
Toshiba Portege R835 with i5 processor 4GB memory.
2TB Seagate hybrid drive with three partitions.
OS - Windows 7 Pro and Windows 10 Pro.
I have upgraded the hard drive a few times and replaced the onboard DVD drive with a Blu-Ray burner.
My previous drive was a 500GB SSD that crapped out on me in about 6 months. My 2TB hybrid drive has an 8GB flash memory section where the most used files get moved to. This is all transparent to the OS and appears as a single drive. Once the system is booted a few times, the PC boots almost as fast as an all solid state drive.
Unless you are into gaming or do a lot of video editing, you don't need to upgrade your memory. I do occasional video editing with my Portege and it works fine. Windows 10 works fine with the 4GB of memory that I have. I have a Windows 10 tablet that I purchased at Walmart for $100 with 2GB of memory and it works great.
I still prefer Win 7 over Win 10. I occasionally boot to Win 10, usually to see if some software will run okay on it. Other than that, I stick with Win 7.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
