ScanDisk Clip+ Can't see audio books on PC
TenOC
I have Rockbox my Clip+. I move audio books from my PC to the Clip+ to listen to the audio books. All has been working well. Today I wanted to add two more audio books to the Clip+. I have lots of space on the 8Gb drive.
The problem is that when I look at the clip on my PC (Drive E) in the place of The existing audio books I see a Wav file "R_MIC_160414-100310.wav" along with 2 sys files. My OS is Win 7-64
I see the same file if I attach to the PC in rockbox or Sansa.
I can still listen to the book on the clip. So the books are on the Clip, my computer (windows explorer) simply can not see them.
I have changed the USB cable and the USB port.
When all else fails contact my RV friends.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
2 REPLIES 2
TenOC
MrWizard wrote:
SOMETHING CHANGED in folder settings on the PC
need to change it to something like view all files ?
control panel
folders and options
show hidden files
show extensions aka (Do NOT hide extensions)
maybe this will help
if NOT
try system restore to a know good date, when everything worked
I tried window Explore and Total Commander on two different computers. No luck.
Travel Photos
MrWizard
Moderator
Moderator
control panel
folders and options
show hidden files
if NOT
I can explain it to you.
1997 F53 Bounder 36s
