TenOC's avatar
TenOC
Nomad
Dec 13, 2014
Audiobooks and ScanDisk Clip+
Today I received my Clip+. I notice that the original firmware has the option to "play all" tracks in a folder. I installed Rockbox. I can not find a play all option. Some of my audiobooks have 100's of "tracks" which are only a few minuets long. I would like for the Clip+ to play all of a audiobook without me needing to select each track.
Suggestions are welcome.
1 Reply
  • You don't need a play all option...Rockbox will play all of the 100's of tracks one after the other. I presume you have all of the 100's of tracks for a particular audiobook in a folder? The order in which the audio files are played is contained in the file itself by numbering the track, and that has nothing to do with Rockbox.
    If you wish there are a miriad of programs that will allow you to create a playlist and Rockbox will play the playlist. Personally I have never found the need to do that and I have listened to many many audiobooks.
    Just go into the settings for Rockbox on the clip+, you have many more options to have things the way you like than the original firmware. I especially like my ability to select the way I get to save and control my bookmarks. You can add different themes, change fonts etc. I would suggest you do some reading about Rockbox.
    http://download.rockbox.org/manual/rockbox-sansaclipplus.pdf
