Wrace
Feb 09, 2014Explorer
TV stopped working, fuse blown?
I have this spectra 32" led tv from this thread. I decided not to use it in our trailer and instead put it in our den 2.5 years ago when we purchased it. It gets very little use.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25929033/srt/pa/pging/1/page/1.cfm
A month ago I unplugged the unit from the den and temporarily moved it out to the living room where I plugged it in and it worked fine. The next day I moved it back to the den and plugged it in and it would not work. I confirmed the outlet in the den is hot.
I took the back off it today and spied the fuse shown in the pictures below. You can see the power cord connects right there to the circuit board near the fuse.
I have the following questions I would appreciate some help on.
- Is this fuse blown? I've never seen a fuse like this so I don't know what it should look like or if you can even tell if it's blown by just looking at it.
- I take it this is a solder-in fuse? I'll need to pull the board, de-solder it and solder in a new one?
- Capacitors on this board hold a charge? If so how long until it dissipates? The tv has been unplugged for 3 days.
- Other safety precautions/advice?
Thanks
Thanks
