shastagary wrote:
Do you happen to have a link to the RF switches?
rf switches like these rf remote switches amazon could work there are a lot of different ones available like another person said you may have to put the relay switch boards behind the light fixture and leave the regular light switches to work normally. the remote switches would work with the normal light switches in the off position then.
or these rf remote switches
There are 2 wires at the light fixture, ground and 12V when the light switch is ON. There is no 12V when the light switch is OFF.
Leave the switch on to use the controller. You would have to put a local manual switch at the fixture to turn on the light if the controller fails
