donscomp's avatar
donscomp
Winegard Roadtrip and DVR with DTV....
Hey all,
Have the above mentioned dome.
There are two LNB's. Front entertainment center and rear bed.
So I want to bring LNB 2 from bed to front for DVRing. Right now of course I can record and watch the same thing but. So I did it just temp. by stringing a line down the hall. Everything worked. BUT then once it went to locals it wanted. Or did. switch satellites. One thing I was not use to with DTV. at home OR in other coaches with NO motion domes. Once it does we get the 771 error.
It is set up as follows DTV receiver that use to have at home on a SWM system. And took it out many times with no problem on different dome dishes however. Now. I have it set to 3 LNB, Mutiswitch.
I read that DISH couldnt do a DVR with the roadtrip because of switching sats. But I guess DTV also does it.
Just trying to get the DVR to work with 2 antennas.
BTW the receiver is a HR22-100
No. I am not running HD of course with that dome.
Any ideas would be very grateful.
Thank you
Don
No RepliesBe the first to reply
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
