coventryhaleExplorerJul 06, 2014CCI 7719 solenoid remoalDoes anyone know how to remove the solenoid from the holding bracket in order to replace it with a safe-t-alert unit?
enblethenNomadJul 06, 2014Mine did not have a separate bracket. The bracket was part of the solenoid. The rigid pipe between the solenoid and the regulator supports it.
Related ContentAuxiliary Start Solenoid ReplacementWhy solenoid?CCI 7719 Propane Detector and Solenoid Valve ReplacementDelete a Propane Solenoid Safety Valve?Battery Disconnect Solenoid Fuse
