Kerri's avatar
Kerri
Check List
Crazy question here, but looking for a check list. I have missed checking out our RV each spring in some area. I there a printed check list to check our RV from outside to the inside before you load it up and enjoy the season.
Thank you for your help
Kerri
    Kerri
    If you have an Android phone, look on Google Play Store for RVChecklist app. Pretty good and you can edit the lists for just the things that are for your situation.
    Not sure if it's available on iToyphone or not, but you can get 200 farts apps there if you want them. :)
  • we have check list we use to prepare for a trip
    and a reminder when we leave the camp site. (we have a Sportsmobile with a raisable top and use shore power, hence the reminder)
  • DAWg134 wrote:
    Here is a site that allows you to create a custom checklist from a very comprehensive list of RV-related checklist items. It's very easy to use, and you only select those items that are pertinent to your particular circumstances. Once you are done, it provides you with a digital version that you can either print out or use on a iPad, computer, etc.
    Custom RV Checklist Generator
    Now that is cool - and you can add your own items as well - by following the directions... Thanks for the link - bookmarked it!
  • Mandalay Parr wrote:
    I made my own.
    Yes, me too...and I don't see many "available for download".
    They do work well for RVing...And nothing like being able to customize for your particular needs / camper / etc.
  • I'm not sure, but the OP might be talking more about a maintenance checklist than a packing list...I know I'd be interested in something that was a pretty comprehensive check of fluid levels, battery connections, things to lube, check hot water tank heats, a/c comes one, etc...
  • Make your own list based on your RV and each of your needs. Same thing with a tear down list. When you have that done find someone else's list as offered above and add what you need that you forgot. Some things will change based on the weather where you're going and how much and what type of activities you engage in.
  • Here is a site that allows you to create a custom checklist from a very comprehensive list of RV-related checklist items. It's very easy to use, and you only select those items that are pertinent to your particular circumstances. Once you are done, it provides you with a digital version that you can either print out or use on a iPad, computer, etc.
