โApr-02-2016 09:59 AM
โApr-04-2016 06:35 AM
โApr-03-2016 11:56 PM
kastgire wrote:
Are these a good idea for a travel trailer? I don't have a ton of electronic stuff in mine, the fridge, 12 volt TV, DVD player, water pump, and the converter......
Bobbo wrote:
They are a very good idea for ANY RV that plugs into power anywhere but at your house. All of the devices you mentioned above except for the water pump have electronic control boards. However, if the TV is truly 12v, and not plugged into 120v in any way, it is probably safe.
โApr-03-2016 08:10 PM
kastagire wrote:
Ok, so are the EMS systems basically like a UPS (uninterruptible power source) system for computers? Basically the incoming power charges and battery and passes through the extra, and in the event the power dips the EMS system uses battery to make up the difference?
โApr-03-2016 08:03 PM
โApr-03-2016 08:00 PM
โApr-03-2016 05:58 PM
wa8yxm wrote:
Energery Management System has two meansing.. One is the Progressive Industries EMS units, which have been covered above.. The only comment I will make is the delay control, 15 seconds by default, but you can make it 136.... Make it 136
โApr-03-2016 02:22 PM
โApr-03-2016 01:02 PM
Bumpyroad wrote:
my 30 amp plug in surge guard has a key to bypass it leaving the surge protection intact. no need to unplug it.
SoundGuy wrote:
Specifically which make & model? Surge Guard is a TRC brand name product and I owned the earliest version #34730 portable 30 amp version and it sure didn't offer any way to bypass it, nor I think did the later #34730-001 which replaced it, nor as far as I can tell does the current #34830. Which Surge Guard are you referring to? :h
Bumpyroad wrote:
will check the next time that I have access. mine is about 15? years old. came with a key to bypass it.
but if the current ones don't have it, the exact identity is sort of a moot point isn't it?
โApr-03-2016 11:13 AM
โApr-03-2016 08:27 AM
โApr-03-2016 06:51 AM
โApr-03-2016 06:19 AM
โApr-03-2016 05:24 AM
โApr-02-2016 04:35 PM
Bumpyroad wrote:
I would not get a hard wired one unless it had a bypass feature.
โApr-02-2016 04:03 PM
