jawsthemeswimmi's avatar
Sep 12, 2016
Firs time in the RV with hookups
We're going out for the first time in our RV to a site that has full hook ups. I'm still trying to get how everything works so have a few questions.
1. City water connection - So I think I understand how using the water tank works. Fill the tank with water, turn the pump on, and the pressure from the pump sends the water to the various faucets. Does the city water connection completely bypass the tank/pump since there is already pressure coming from the connection? Is there something I need to change (like flip a switch, close a valve, etc) to make this happen? Does the city water connection on my trailer just feed directly into the water lines?
2. Sewer (Gray/Black) - Do I just connect this like normal and leave the black and gray valves open? Or do you leave the valves closed?
3. Power - Do people use surge protectors or something similar? How do I know what surge protector to get? I'm guessing they all protect against different levels of spikes.
Thanks in advance for all of your help.
