Usmcsousa's avatar
Usmcsousa
Heated tanks?
Hi again folks,
so My Class A has "heated waste tanks" as labeled on the waste tank compartment door.
I'm trying to figure out how this works.
there's no on\off switch that I can find anywhere .
is it an automatic thing? Electric? Should I be concerned about a parasitic load off the house batteries when boon docking?
both my black an grey tanks have a female port to connect a hose and flush the tanks, how often should I use these? I've currently been using them every time I dump my tanks. I'll dump grey than black, then fill the tanks at those fittings with the outdoor shower hose mounted adjacent to the tank. Then dump again.
any help or advice is appreciated as always.
thank you
Semper Fi.
